Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:33 am
Solution
ParticipantIn Mechanical it is possible to create a beam chart by using Beam Results scoped on a Path. Please check the attached document.
1. 2062383.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
