1) What is displacement convergence? 2) In some cases force or displacement convergence alone is sufficient while in some other cases both are activated. What is the reason for this?
April 13, 2023 at 7:33 am
SolutionParticipantDetails are given in the attached document.
1. Understanding_Displacement_Convergence.pdf
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
