General
General
Two different rigid constraint equations are generated and saved to file.s01 and file.s02 files. When user attempts to run this solution with LSSOLVE,1,2,1, he gets: ************** Error: Constraint equation 1 does not exist. The CECMOD command is ignored. ************** He can do this without error using sequential solves without leaving solution. What is the problem?
    • SolutionSolution
      Participant
      Please refer to the attachment(s) to access the Solution.
      1. 395446.pdf
