Tagged: 2021 R1, fluent, fluid-dynamics, General, General - FLUENT
April 13, 2023 at 7:33 am
SolutionParticipantRegarding reducing the frequency of residuals printing, please follow the below steps. Once initialize the case, go to Run Calculation Modify the default value 1 to xx under the Reporting Interval For example, specify 10, Residuals will print every 10 iterations. Attached the reference picture.
- Skewness in ANSYS Meshing
