Tagged: 18.2, hyperelasticity, materials, mechanical, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantOne might be able to approximate this material behavior with a simple 2 term hyperelastic yeoh material model. With two data points, one could use the formula on slide 29 of attached training material to convert young’s modulus to shear modulus (mu), assuming Poisson’s ratio =0.50. The Cio coefficients are related to shear modulus via equation on slide 10. It is best to get a full compliment of test data in tension, shear and compression to fully characterize the material.
1. Mech_ANL_16.0_L04A_Hyper.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
