Tagged: 19.2, Explicit - LS-DYNA, export, lsdyna, mechanical, structural-mechanics
April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer to the attached document to access the solution.
1. 2058027_Solution.pdf
