When I create a workbench object “Fluent with fluent meshing”, I add the geometry and then open meshing, it will only use the watertight geometry option, the option is “greyed” out. It does not show fault tolerant workflow.
Tagged: FLUENT Meshing/Tgrid, fluid-dynamics, meshing
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: fault, workflow, tolerant
1. 2066695.pdf
- Skewness in ANSYS Meshing
