General
General
What is the meaning for columns in elout file?
    • SolutionSolution
      Participant
      In this elout file, element IDs are 1,2,3, (labels “1-“, “2-“, “3-“), each has integration point, material ID is 2 and stress state is elastic. i.e. the first two columns each have two entries interleaved – element ID and ipt in the first column, part ID and stress state in the second. States can be “elastic”, “plastic”, or “failure” effsg is the effective stress “yield function” output the contents of the effective plastic strain slot. Please refer to the attached snapshot.
