April 5, 2023 at 2:33 pm
FAQParticipantTo measure volume flow rate through an inlet/outlet, integrate the velocity across the inlet face in the direction normal to the face. Refer attached image. The value of the integration will be a scalar, so the “Component” dropdown has no effect here.
- Skewness in ANSYS Meshing
