For what applications is the new material option: Coupled Damage-Plasticity Microplane Model with stabilization recommended?
Tagged: 19, mapdl, materials, mechanical-apdl, plasticity, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThis material model is suggested for general geomechanical applications exhibiting considerable plasticity with softening behavior that dominates to the point where the conventional options (MPLANE,EDP, CAMCLAY) have convergence difficulties.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- Hyperelastic Simulations
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
