Are the outputs of the generated state-space matrices positions and orientations along and around the x, y, and z axes? If not, what are they?
Tagged: 19.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThe state-space matrices A, B, C and D are specified in the help documentation section 14.17. Reduced-Order Modeling for State-Space Matrices Export (help/ans_thry/thystatespacemat.html).
