General
General
How to combine multiple domains in CFD-Post so that the volume average or volume integral can be calculated on multiple domains
    • FAQFAQ
      Participant
      1. Insert > Location > Volume. Here lets call it “Volume 1” 2. In the Volume settings specify the following: – the domains to be included by multi-selecting the them in the Domains list – set Method = Sphere – choose a Point at the center of the model – choose a Radius that will encompass the entire model – set Mode = Below Intersection 3. Now, you can calculate the volume average with the expression volumeAve(Pressure)@Volume 1
