Cells are marked. The marked cells are patched with one phase. But still can not see that in contours.
April 5, 2023 at 2:32 pmFAQParticipant
Please mark rest of the cells. Then patch these rest of the cells with desired volume fraction of the phase. This will give you difference in contours.
- Hydrodynamics and Wave Impact Analysis
- What do “incomplete” DPM particle tracks mean?
- Simulation of Exhaust Gas Recirculation (EGR) Cooler with CFD
