Tagged: 18, mechanical, rotordynamics, structural-dynamics, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantNo, ANSYS does not support a rotordynamic analysis of a cyclic symmetric model.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
