April 5, 2023 at 2:32 pm
FAQParticipantThe answer is No. The Nastran .dmig file is a text file that acts basically like our superelement binary file (.sub). It is used to represent the stiffness (and mass) of the structure without supplying the FEA details. In order to do this in a practical manner, though, the user needs to specify the master DOF and perform a substructure analysis. Basically, we don’t just dump the [K] matrix from the .full file as a .dmig file because the .full file contains the entire FEA mesh and thus has a lot of unnecessary information. Instead, what should be done is to identify the ‘attachment points’ (where this model will ‘connect’ to other parts in the other model), and the stiffness (and mass) matrix of the subassembly will be calculated in a substructure generation pass. This is in the .sub file, which can then be exported to a .dmig file.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
