April 5, 2023 at 2:32 pmFAQParticipant
In a structural transient analysis, when we have damping, we see a phase lag due to the damping term (being proportional to velocity rather than displacement). In a transient FSI analysis, the situation is different – Fluent does not give Mechanical a damping matrix. Instead, Mechanical passes displacements to Fluent, which returns forces (pressures).
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to include effect of bolt pretension in a modal analysis?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
- Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
- ANSYS Mechanical: Vibration Housing Noise
