Tagged: 19.1, FE Modeler, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantIf user is at 19.1, then FE Modeler is hidden as it is going into unsupported mode. They need to go to WB Project Schematic page,Tools> Options> Appearance> Unsupported Features> Tick. This will make FE Modeler to appear in the toolbox. Please note that this is “Unsupported” tool from R19.1. The user can user External Model to import files in WB.
