In Fluent, which DEFINE macro can be used to implement a user defined Interfacial Area Concentration (IAC) kernel?
April 5, 2023 at 2:32 pm
FAQ
ParticipantIn principle, IAC applies to all kinds of dispersed flows. This includes droplets in gas droplets in liquid and bubbles in liquid. However the kernels used for break-up and coalescence are only valid for air bubbles in water. To model breakup and coalescence correctly, it is necessary to implement applicable kernels with a UDF DEFINE_PROPERTY is used to modify and implement the IAC kernels.
- Hydrodynamics and Wave Impact Analysis
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
