General
General
How to see the nodes not mapped for the warning message?: During data mapping, target nodes were found outside the boundaries of the source point data. A different method may have been used to calculate the interpolated value. You can find more information by looking at the Summary comment or by turning on named selection creation for outside nodes to help identify these areas.
    • FAQFAQ
      Participant
      To see the nodes that are outside the mapped region: Go to the details of Imported Body Temperature and turn on the named selections for left out nodes during mapping: Details of Imported Body Temperature > Named Selection Creation > Outside Nodes – On. Re import Temperature Load and Examine the Named Selections created and note that Outside Nodes are in the Min/Max incorrect Temp areas.
