Tagged: 19, fracture, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThe ending time doesn’t really matter – one can use default of 1 “second”. For question on DTIME, “CGROW,DTIME” ,that solution option parameter is not required – it’s helpful if you want more control over the timestep size for crack growth.
