How to access the number of used compute nodes via Scheme and without going through the /parallel menu?
Tagged: 19.1, FLUENT - SYS, hpc, HPC/Parallel, Installation/Licensing/Systems
April 5, 2023 at 2:32 pm
FAQ
ParticipantOne can access the number of nodes by using (compute-node-count).
