In CFX, how can I access the volume fraction of an Algebraic Slip Model (ASM) species, e.g. for the calculation of drag force in User Fortran? I get a message that this is not available
Tagged: 10, cfx-solver, fluid-dynamics, General, multiphase
April 5, 2023 at 2:32 pm
FAQParticipantThe limitation on volume fraction is caused by settings in the VARIABLES file. You can find this in the etc subdirectory of your installation directory. By default, volume fraction is designed for multiphase cases. You can though extend its scope by putting some additional lines in your ccl: LIBRARY: VARIABLE: vf Physical Availability = ALL Variable Scope = PHASE,COMPONENT Variable Class = MCF END END You will need to edit the ccl outside the CFX-Pre GUI otherwise the checks will be applied again and your modifications removed. In your call to USER_GETVAR, make sure that you use the correct syntax for the volume fraction, e.g.: CALL USER_GETVAR(‘MyFluid.ASMspecies.Volume Fraction,………) where MyFluid is the name of your multi-component mixture.
- Skewness in ANSYS Meshing
