Why do FSUM,RSYS results in a cylindrical RSYS differ from FSUM results when SPOINT is specified and the same cylindrical RSYS is active.
Tagged: 16.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantFSUM,RSYS transforms the individual nodal forces into the cylindrical coordinate system before summing. FSUM with SPOINT sums the forces in global cartesian and then transforms the sum.
