General
General
How to have two geometries with same variable names but different values?
    • FAQFAQ
      Participant
      Say you have a geometry with design variables a = 1, b = 1, c = 1. And you want to add a scaled version of this to the same design with a = 3, b = 5, c = 2. You want to use the same variables to control two different geometries. The way to do this is through 3D components. Create a 3D comp of the geometry with variables a, b, c and insert it into the design that already uses same variables. Now you can independently control the geometries using same variable names.
