March 17, 2023 at 1:12 pm
Solution
ParticipantSee the presentation attached to this solution. Note this was originally presented as a Webinar in French. The Webex recording can be viewed at https://ansys.webex.com/ansys-fr/lsr.php?RCID=351c8eb2af1b4dc1b1bd334c372ee9f5 The original presentation in English is also attached
1. 2042351.pdf
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
