March 17, 2023 at 1:11 pm
SolutionParticipantKeyword: ECAD, trace mapping, ODB++, TGZ Please download attachments to access the workshop
1. 2063608.zip
2. Electronics Applications in Ansys Mechanical 2019 R2 (Workshop Presentation).pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
