How can one convert frequency and temperature dependent viscoelastic data to a prony series for use in ANSYS Mechanical?
Tagged: 15, materials, mechanical-apdl, Special Purpose, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2037069.mp4
2. 2037069.zip
3. 2037069_corrected.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
