March 17, 2023 at 1:11 pm
SolutionParticipantEliminating brake noise is a classic challenge in the automotive industry. Brake discs develop large and sustained friction-induced oscillations, referred to simply as brake squeal. This example shows how to use Brake Squeal analysis in WorkBench (partial or full non-linear perturbed modal).
1. 2042996-a.pdf
2. 2042996.pdf
3. 2042996.zip
