When open Design Modeler or Mechanical, Script Error: Microsoft JScript runtime error; Index out of bounds
Tagged: General, mechanical, Reset Appdata, script-error, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantThis error corresponds to corrupted WB environment files. A simple reset should fix the issue, please refer to the attachments for the procedure.
1. 2055276.pdf
