Compiling and Loading User Defined Functions using Fluent and Microsoft Visual Studio 2017 Community Edition running ANSYS Fluent in Serial and Parallel
March 17, 2023 at 1:11 pm
SolutionParticipantPlease download the attached resolution document for detailed instructions. Also, see attached udf-batch_file-2017 to support the 2017 Express compiler and Build Tools. Also, needed for Fluent 18.2 and earlier versions.
1. 2049257-udfs-2017.pdf
2. 2049257.zip
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
