Multiphase Flows
Multiphase Flows
How do I model the influence of an electric or magnetic field on a charged particle?
    • SolutionSolution
      Participant
      The UDF in this solution assumes the use of either the standard electric field model or a user supplied magnetic field. Particles are “charged” randomly by setting a DPM Scalar value to represent the number of electrons. The force is applied using the DPM_BODY_FORCE UDF as the force is not applied directly by the fluid as with DPM DRAG.
      1. 2055111.zip
