Tagged: 17.2, fluent, fluid-dynamics, Mesh Deformation, meshing, Moving/Deforming Mesh
March 17, 2023 at 1:10 pm
SolutionParticipantPlease see attached video. The video shows the problem during creating sliding interface after using slit-face-zone command and it also shows the workaround. Keywords: planar rotating sliding interface, slit-face-zone
1. 2045837.zip
- Skewness in ANSYS Meshing
