Are there plans to port Workbench for the 64-bit Linux Opteron systems? And, if so, when is it planned to be available?
March 17, 2023 at 9:01 am
FAQParticipantYes, we are planning a port for AMD Opteron 64-bit for Workbench 12.0.
