Is it possible to open a dsdb, agdb or wbdb file that is created on ANSYS Workbench 10.0 sp1 Windows 64-bit system on a 32-bit installation?
March 17, 2023 at 9:01 am
FAQParticipantYes, that is possible, and supported (assuming that you don’t go over the memory restrictions on the 32-bit system).
