On trying to start ANSYS 10.0 on an AIX 5.3 system, the following error occurs: Could not load program /usr/local/apps/ansys_inc/v100/ansys/bin/aix64/ansys.e100: Symbol resolution failed for /usr/lib/libGL.a[shr_64.o] because: Symbol aixgsc (number 82) is not exported from dependent module /unix. What is causing this error and what needs to be done to allow ANSYS to work on this system?
March 17, 2023 at 9:01 am
FAQParticipantInstall the following filesets from AIX5.3 CDs: OpenGL.OpenGL_X.dev.vfb X11.vfb
