Licensing
Licensing
Gzip fails when using FLUENT, causing the application to crash. The problem is related to the gzip version that Fluent packages. Likely error: “gzip.exe has stopped working” or cannot write out gzip file…
    • FAQFAQ
      Participant
      Resolution: Close out of Fluent and Workbench. Download a new copy of gzip from http://www.gzip.org/gzip124xN.zip Extract and duplicate gzip.exe to gunzip.exe, and then replace the gzip.exe and gunzip in C:Program FilesANSYS Incv172fluentntbinwin64 with the new ones. Restart Workbench or Fluent and try again. This defect has been fixed in Release 18
