After carrying out the CAD configuration for PTC Creo in a ANSYS 2019R1 installation on a Windows operating system why does the link to Workbench 2019R1 appear in the PTC Creo toolbar but not the link to APDL 2019R1?
March 17, 2023 at 9:01 am
FAQParticipantThe following additional step needs to be carried out. To make the link to APDL 2019R1 appear. Open the file, C:Program FilesANSYS Incv193ansysac4dataprotextac4pro193.txt Open up a text editor Choose Ctrl+H to open the replace option Find what: 193 Replace with: 2019R1 Replace all File/Save File/Exit
