FlexNet Licensing error: -101 All licenses are reserved for others. Customer has options file “RESERVE 1 electronics_desktop HOST hostname” however ansyscl.exe is requesting based on FQDN.
March 17, 2023 at 9:01 am
FAQParticipantAdd the following to the options file to treat FQDN and short names equally # Ignore FQDN vs short hostnames FQDN_MATCHING lenient
