According to PLCAMP documentation for the new ANSYS 10.0 command PLCAMP, a comparison between complex mode shapes is used to track the modes versus the rpm excitation axis. Could you provide further information what is done here for my advanced dynamics seminar? Is it a sort of MAC (modal assurance criterion)?
March 17, 2023 at 9:00 am
FAQParticipantYou are right. We are using the modal assurance criterion to compare the complex mode shapes at 2 different load steps. If the result if less than 0.7, we issue a warning to let the user know that sorting may not be satisfactory.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
