Why does Contact stiffness (Normal and/or Tangential) reported in Contact Tool not match what is reported in Results Tracker?
March 17, 2023 at 9:00 am
FAQParticipantAssuming the contact tool is under the Model branch, it would be an initial value. The tracker should be after first iteration. With NLGEOM, off, we are probably solving in one iteration (NEQIT,1). With NLGEOM,on, it is probably multiple iterations. Do they match if you turn off stiffness updating scheme?
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
