Structural & Thermal
Is there any way to automatically turn off the ‘Program Controlled’ small sliding logic in WB-Mechanical Contact? Will CNTR,revision,xx.x do this?
    • FAQFAQ
      Participant
      The small sliding logic is set automatically by WB mechanical for small deflection and bonded contact. CNTR logic can not turn this off. You can you keyo,cid,18,0 in the end of /prep7 to manually turn off small sliding logic.
