Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantNo, it is not possible as ANSYS modify mesh and geometry location at required points when nonlinear adaptivity has been used. Thus while exporting, we get results based on updated geometric location.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
