Tagged: 18.2, mechanical, meshing, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIn Mechanical, click on Model from tree outline. Click on Mesh Numbering Icon from menu bar (on top of Geometry view window). “Mesh Numbering” term will appear in tree outline under Meshing. Right-mouse-click on Mesh Numbering and insert Numbering Control. You can change begin node and element number in the details of Numbering Control.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
