With regards to Multilinear Kinematic Hardening, Section 4.4.3.2.2 states “No segment slope can be larger than the slope of the previous segment.” However, it appears to run without error. What is the reason for this note if the solver runs anyway?
Tagged: 2019 R1, materials, mechanical-apdl, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantAn increasing KINH slope segment is generally not recommended as it might lead to negative volume fractions for the different KINH layers and if slope increase is large enough, it might not be physically realistic. Hence, the doc note. Starting at R2019-R2, a warning is issued: “The TB,PLAS,,,KINH table for material # at temperature ## has a segment slope (***) larger than the previous segment slope (**). ” Background: The older formulation (TB,mkin) error trapped this and the solver would not proceed. This trap was considered too restrictive as it did not accommodate minor “noise” in some user’s data that turned out to be tolerable.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
