In abaqus, we have an option to define plastic data using “yield stress” ”ultimate stress” and “Plastic strain at yield” and ultimate“ in kinematic hardening. How we can define it in ANSYS
Tagged: 19.2, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIn ANSYS, one can use bilinear Kinematic hardening model where tangent modulus can be calculated using below expression: Tangent modulus=(Ultimate stress-yield stress)/plastic strain at ultimate point
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
