March 17, 2023 at 9:00 am
FAQParticipantYou can use following logic to extract the result. ————————————————– Since 2^x = e^(x*ln(2)) you can do: *vget,prin1,node,1,s,1 *vfact,1,log(2) *vfun,udr,exp,prin1 *vput,udr,node,1,epel,xz /graph,full plns,epel,xz
