General
General
Is it possible to select imported STL supports for removal in the AM Sequencer (2019 R2)?
    • FAQFAQ
      Participant
      The STL Support removal has been implement in 2019 R3. A workaround in 2019 R2 is to use Command object with EKILL or Element Birth and Death condition objects.
