Can we use write input file and read results file options during explicit analysis like we can use during static analysis?
March 17, 2023 at 9:00 am
FAQParticipantExplicit dynamics use autodyn instead of Mechanical APDL as solver, so it read/write input/results are not supported in explicit.
