General
General
If a spring is attached to a body with deformable behavior should the displacement of the spring be consistent with the deformation of the body?
    • FAQFAQ
      Participant
      The spring displacement is not directly based on the deformation of the body to which the spring is connected. It will be based on the reaction in the spring ( F= Kx) where x is the displacement of the spring.
