General
General
Can you use the EKILL command within a modal analysis?
    • FAQFAQ
      Participant
      No. The EKILL command may be used in static and nonlinear transient analyses where the Newton-Raphson solver option is set to full explicitly in the first load step. In Ansys, modal analyses are linear by definition.
